Learnt a few things today.
- when using an i2s connection, and when doing comparing to USB connection, leaving the USB cable plugged in and trying to switch back to i2s, the dac will not get a lock back with the i2s connection. The usb cable needs to be removed from the back of the dac, or, the dac needs to be restarted. The usb cable cannot be left plugged into the dac (with the other end unplugged from the source).
- sotm, innuos phoenix, singxer su-6, i2s, Rockna sounds better than sotm, phoenix usb, Rockna
the su-6 or i2s connection (or both) is making the improvement. Either way, i2s sounds better with the rockna.
- i had previously updated firmware by playing the firmware update wav through the dac. Today, when using the Rockna app to put the dac in standby, it said there was a new firmware available and asked if I wanted to update. I pressed ok and UPD.xx% showed up on the dac. After 100% it showed UPD.DONE
but firmware was the same as the one I had previously updated. :|
So with Singxer su-6 the rockna wavelight works with I2S mode 2 = PsAudio Pinout? Did you try other DCC interface? Gustard U18, Denafrips or....?
no issue with DSD 256with the sigxer su-6 fully high sample rate?
