Rockna Wavelight
- Thread starter koven
ThanatosVI
Thx for explaining and the picture.Upcoming Wavelight Server has inside storage place too. Up to 3 4TB SSDs - so up to 12TB.
2.5" if I see that correctly.
ThanatosVI
Soo it's finally here.
Hardest part is to not use it the next few hours.
It was amazingly well packaged with the silk envelope.
I bought mine used and it basically came with nothing but a power chord.
It has no remote right? (App will be used for that)
m-i-c-k-e-y
@ThanatosVI you using Single ended or balanced?
angpsi
Hi guys, has anyone compared the Wavelight with dCS offerings such as the Debussy or the Bartok?
ThanatosVI
Single ended since I use a Schiit Loki in the chain@ThanatosVI you using Single ended or balanced?
ThanatosVI
How can I pair the DAC with the remote App?
The App never finds the DAC, how do I Set it in pairing Mode?
Edit:
Weird with by Tablet it works flawlessly with my Smartphone it doesn't
Lol UAPP recognizes the Wavelight as Hydra Vox
Edit2:
On the tablet the app starts, but nothing I set there gets aknowledged by the DAC
Edit3:
Control Firmware update terminates with upd.err.16
FPGA update requires a login, I now contacted Rockna.
Edit4:
Several control firmware update tries later it was successful, my tablet now works flawlessly as remote
My Smartphone never connected even once
Edit5:
Rockna Support is very fast and FPGA Version 1.10 is available since 2/11/2020
Edit:
Edit2:
Edit3:
Edit4:
Edit5:
ThanatosVI
So all firmware updates successful.
Rockna support is great.
However my Galaxy S10 still can't connect to the Wavelight. Only my Galaxy Tab S3 can
my pixel3 and note20 ultra wont connect to rockna after 1.10 fpga update.. it connected before. my control version is still 1.22.
ThanatosVI
Latest control Version is 1.28my pixel3 and note20 ultra wont connect to rockna after 1.10 fpga update.. it connected before. my control version is still 1.22.
can't upgrade control ? since my app wont connect lol.Latest control Version is 1.28
ThanatosVI
Listening for a few hours now.
The raving reviews did not exagerate, the Wavelight lives up to the hype.
Also seems to have amazing synergy with my System.
m-i-c-k-e-y
What do you feed your Wavelight from?
