Steve999
smooth, DARK
- Jul 15, 2002
I haven’t any experience with Chord products whatsoever so can’t pass any personal judgement.
Some of their products certainly look exotic, one of them even looks like a spaceship.
To Whom It May Concern:
I have one of these lying around the house because I used it to make digital recordings of LPs. . .
https://www.guitarcenter.com/Behringer/UPHONO-UFO202-USB-Audio-Interface.gc
But I'd recommend the Behringer UCA 202 if you don't need to digitize LPs. It's more versatile and sometimes a few dollars cheaper.
SO:
Maybe you could try one of these things--$20 or $30. . . a possible but rather extreme cure for the placebo syndrome. . . The real medicine may be too strong! It's like moving to the P-Funk from disco!!!! (This was reportedly George Clinton's motivation when he recorded the LP Funkentelechy versus the Placebo Syndrome... highly recommended by yours truly.) Anyway, I have the 202-family Behringer DAC with the phono preamp in it . .
On to my narrative I wrote before I got sidetracked AGAIN and AGAIN:
I got curious tonight and I've done a little research for you and I'm giving you five independent sources to look over in case you are skeptical (and why wouldn't you be?). You've got a detailed review with measurements and history, a musician, an audio geek, and an audiophile, and a bunch of Amazon customers. You'll see people put these to quite different and varying uses and in very demanding situations.
They're worth their weight in plastic and, um, whatever else they're made of!
First:
http://nwavguy.blogspot.com/2011/02/behringer-uca202-review.html
From the article directly above I learned this should be a great headphone amp for my Beyer studio phones (DT880s and DT990s) and my Senns (HD 580s) but not for my cheaper low impedence headphones. However, as far as using it for a DAC per se, or using the line outs, you should be golden. I checked the volume on my 200-ohm headphones and it's in excess of what is comfortable for me so I can use my nicer headphones with this. You can also read in the directly above article about a double-blind test (DBT) where audiophiles couldn't tell the difference between cheap Behringer and Sony components with intentionally sub-optimal cables versus super-expensive audio components. The article is nice because it doesn't pull any punches--it points out strengths and weaknesses of this Behringer DAC alike and then puts it in perspective for you. It was also good book learning material for me. And after reading the article I am using it right now to listen to my nicer headphones outboard from my computer.
Honestly, I have two more expensive DACs so I am not immune to being human. Although they are worth it in some ways for some of my headphones because they are more suitable for a wider range of headphones due to their variable or lower output impedance for the headphone monitor jack. And they serve other functions. I read! I learned!
The above-linked article and the second video will show you the internals of this DAC and how seemingly comically simple the board layout of a DAC can be if done well.
The article and the second video have some differences in opinion you can look for. It just means you are getting more learning and information. I can try things out at home and see what I think because I paid my $30 to THE MAN (i.e., Jeff Bezos).
Now, on to the fluff:
Amazon Customers:
https://www.amazon.com/BEHRINGER-U-Control-Low-Latency-Interface-Digital/dp/B000KW2YEI
Musician who records using IPad:
Techie guy:
Audiophile:
