Nellie75
Which Pro version do you have?I use my Pro for vinyl on a regular basis. Works perfectly.
Are you running it with a preamp phono stage or directly from MM turntable to the Pro?
Version: Pro FS R BE (although version does not matter because all pro versions handle AD conversion the same).Which Pro version do you have?
Thanks, I really like my Burson Soloist paired with a ADI-2 DAC. I like ADC options in the Pro version but not sure the ADI-Pro alone would sound as good as my current setup.Version: Pro FS R BE (although version does not matter because all pro versions handle AD conversion the same).
Schiit Mani Phono Preamp
If ASR is anything to go by the ADI-2 DAC as well Pro build in amp is better than the Burson 3XP in virtually every way except power delivery. The Pro would be a no brainer for me unless you really need the extra juice.Thanks, I really like my Burson Soloist paired with a ADI-2 DAC. I like ADC options in the Pro version but not sure the ADI-Pro alone would sound as good as my current setup.
I'd love to hear from someone who has compared the Burson 3XP to the ADI-Pro
How is the soundstage and depth of the Pro?If ASR is anything to go by the ADI-2 DAC as well Pro build in amp is better than the Burson 3XP in virtually every way except power delivery. The Pro would be a no brainer for me unless you really need the extra juice.
I use the Topping A90 on my turntable. Paired with a grado PS2000E it does not sound to dry and the PS2000E is really awesome because it generates holographic sound. I use the adi-2 pro as dac and headphone amp on my digital rig (fiio m17 ).How is the soundstage and depth of the Pro?
I have a Topping A90D and it is just dry and 2 dimensional. I like my Burson much more.
The Burson is holographic with a lot of depth. It’s smooth yet articulate. Makes my Aryas shine.
That said, I’ve got 15 days left on my return window for the Burson and the ADI-2 dac so I’ll need to decide quickly
Yeah, it’s not dry but when directly compared to the Burson, it is drier and definitely a shallower soundstage.I use the Topping A90 on my turntable. Paired with a grado PS2000E it does not sound to dry and the PS2000E is really awesome because it generates holographic sound. I use the adi-2 pro as dac and headphone amp on my digital rig (fiio m17 ).
The DSP is limited to sample rate of 96kHz if I am not wrong.Does the ADI Pro FS BE lack any features of the ADI-2 FS?
I know the IEM jack is missing (I don’t care about that). What about functionality with iOS devices via USB? Or DSP stuff? Any other missing features?
I’ll mainly considering RME for the remote, iOS playback and turntable playback through headphones and loudspeakers. Hoping the headlamp can compare to a A90D. I most look forward to the EQ settings, Loudenss mode, L/R balance, DSP and connection to a powerful preamp and power amp setup in my living room.
You can save different set ups and eq profiles then give them custom names, it is very easy to switch between themIs it possible to setup a separate EQ for the XLR out (this goes to my headphone amp) and a different EQ for RCA out to my preamp/speakers?
I’d like to avoid plugging in a line out cable on the front headphone jack to my preamp/speakers.
Okay, so I could name one EQ “HD600” and another one “Speakers” and then easily switch between them? That is good.You can save different set ups and eq profiles then give them custom names, it is very easy to switch between them
I don't think you can have different eq active at the same time however
Yes all settings are savedOkay, so I could name one EQ “HD600” and another one “Speakers” and then easily switch between them? That is good.
However, is Left/Right balance also saved in the preset? My right ear needs more volume than the left. Of course speakers I want left alone.
Output is higher than previous model!Looks like RME are about to release a new model, the RME ADI-2/4 PRO SE DAC. It has higher headphone output and 4.4 balanced connection. I will be buying asap on release, the only thing that has prevented me from buying the ADI Pro 2FSR is the weird balanced adapter and lower headphones power output.
