maarek99
- Aug 24, 2004
I did some cable testing a while back. The results were astonishing. I used my 0404 as the source. Loopback testing using rmaa 5.1 for measurements. Here's what I discovered:
1. Standard 0404 breakout + 5 meter radioshack ic.
http://hmcindie.pp.fi/movies/rmaa/RM...rd%20cable.htm
2. Standard 0404 breakout + 0.6 meter Van den Hul "The Name" ic
http://hmcindie.pp.fi/movies/rmaa/RM...0den%20hul.htm
As you can see, no differences at all. But when I put the headphile breakout on the 0404 (blacksilver) I saw some dramatic changes:
3. Headphile breakout
http://hmcindie.pp.fi/movies/rmaa/RM...0headphile.htm
I mean, what the hell? Headphile gives consistently worse results than either the standard breakout box with a 5 meter radioshack cable or the 0.6 meter van den hul. The noise goes up, imd goes up and stereo crosstalk goes up. And by a pretty large amount too! These tests were made several times and they always looked the same.
Weird. On listening tests the headphile seemed lacking bass but adding extra treble energy eventhough the frequency response looks the same as with all the other cables.
What's going on?
What's going on?
