xXMeMoXx
- Feb 21, 2016
Hi.
guys i can't decide which one i should get the T10i or the T20i and why?
Hi.
Hi.
Hi.
Hi.
Just got the T20i's today, out of the box I'm really happy with how they sound. They look great in black.
One thing that I did find strange though is that the right ear hook (side with the mic) is slightly longer than the left ear hook, is that normal? Its not much longer but long enough for it to be noticeable, around 5 or so mm longer. I also found that where the cable joins the ear hook the cable must have been crimped when in the box so its not sitting straight after the plastic joiner, I'm sure it will straighten up in time though.
I think that I have just been looking at them for to long since I got them out of the box.
Don't have the mic version, so I can't comment on you first observation, but a number of people (including me) have noticed that the packaging tends to put a little crimp or indentation in the wire. Doesn't really hurt anything but with such a great IEM and nice packaging, it would be good for RHA to address this by replacing the hard plastic in the packaging with cardboard or something a little softer. They do sound great out of the box and will get even better with a little use. The T20 is once of only 2 IEM's I've noticed a break-in. You might want to get yourself some Comply T200's, they really help the bass dig clear to the bottom. For some reason I had no trouble getting a good seal with the included tips on the RHA M750 but had trouble with the T20. IMO, you bought the best IEM under $250 although I haven't heard them all.
Just received the T20i and they sound terrific. I confess I was not counting with something this high fidelity, competing really close with the "top-tiers".
Welcome to the party, my friend!
Burning them in at the moment, seems that these do change a bit and right now I need a small improvement overall.
