lindrone
King Canaling
- Aug 25, 2003
Well, that's a different type of cable than the one I have now. The one I have now is fully integrated, and not replaceable unless I send it back to Sensaphonics.
I like the elegance of the integrated cable as opposed to the plug though. I'm still considering switching to the breakaway cable for my 2X-S, because 45" is just a tad too short for me. I don't know it's worth the trade-off. Probably will meet with my audiologist sometime this week to see what's up.
I think you missed this earlier post...
I hope the original review, plus the additional comments are enough to answer your question, lojay. If not, let me know if you have any other specific questions.
The reason why I'm still keeping the CD3000's... there are still times when I just don't want to put anything in my ear.
Originally Posted by Big D You've completely missed Lindrone's point as the Sensa cable is replaceable too. Just half way down the cable, not at the earpiece. |
Originally Posted by lojay So, can you tell me the reason why you'd choose the canalphones over the CD3000 or vice versa? |
Originally Posted by lindrone I think this review should give a good idea.. I'm too lazy to write another one comparing CD3000 against the UE-10 Pro, but you get the idea... http://www5.head-fi.org/forums/showthread.php?t=70159 One addendum: I think 2X-S does have one advantage, because its excellent microdynamic in its decay, and the extra richness and warmth, it gives it a characteristic that stands out apart from the CD3000. Whenever something is outstandingly different from one headphone to another, it really gives you that immediate impact value, and allow you to appreciate it much more easily. UE-10 sounds more like CD3000 in its colder presentation, although the level of detail is higher and clarity is better. It doesn't have as much of a "differing" characteristic that makes it more special in comparison. However, even though it doesn't have a stand-out, differentiating characteristic, it is still an excellent headphone that I would rate above the CD3000 overall. |
