HeadphoneViking
WARNING: BAD TRADER
- Mar 15, 2012
Could you by any chance give any thoughts on it compared to the Musical Fidelity M1 HPA?
As I own both the SPL Auditor and the Violectric HPA V200 I feel like I should chime in with my impressions of them both for a bit. Given that both are solid state amps that cost about the same I was surprised by how different they actually sound. The difference between them is pretty much as has been described by many already so the V200 has a bit more bass, but is noticeably less transparent than the Auditor.
I have the HD 800, T1 and LCD-2 and to me it feels more like you pick whichever of the amps based on the sound you want because both sound very good. They just have a different style to them. With the T1 Auditor wins hands down, for the HD 800 I can't decide which I like most and for the LCD-2 I have no idea yet as I haven't compared them in so long I can't actually remember what it sounded like with the Auditor. This might not be much to go on, but it's all I got now!
Hello,
I am new to this hobby. I just purchased my first headphones (D7000). Believe it or not I became interested after listening to a pair of Beats at the local best buy and started researching the subject. Anyways, I was wondering what Amp and Dac you would recommend for D7000s. My source would be my computer. I will be playing mostly Classics, Soft Rock and some Electronic music (FLAC files). My budget is around $2000 for both the Amp and the Dac. Spending some time in this forum I realized that the D7000 are not the best choice for classical music. Oh well, I still like them. I am sure I will be buying more HPs ( HD-800, T1, LCD3....etc) down the line, with respect to that My first choice is Violectric V200/V800. I would appreciate any comment, help or suggestions. Thank You
Hello,
Thank you for the info. I really appreciate it. I was about to purchase the V200/V800 yesterday, and then I read Project86's review on V800. Sounds like I wont be able to stream 24/192khz from my imac to V800 ( via usb). Does this mean I need a USB to SPDIF converter ( like the U2 from Anedio) so I can feed it to Coaxial input of the V800 that accepts the 24/192. Any other suggestions for feeding 24/192 from computer to V800? one more questionwhat do you think about the Anedio D2 Dac ( i mean I have to spend on some sort of converter on top on V800 to stream 24/192 from mac and that would make up for the price diff between V800 and D2 dac. And then there is the Question about if V200 is a good match with Anedio D2 dac? Thank you for your time.
