lindrone
King Canaling
- Aug 25, 2003
I got my Pocket Reference back from LaRocco (with the gain readjusted) and was able to do a more comprehensive side-by-side comparison with my HR-2.
ProPhonic 2X-S was amazingly consistent.. it held its basic sound signature very well, while picked up on the differences that each amp delivered in a very apparent, yet not overtly dramatic way. This all goes to show that 2X-S will execute on its basic sound signature in a very consistent manner, despite the source and amp. Yet at the same time, it doesn't take away from the advantage of having a better amp and source either.
The combination with the HR-2 is darker, with more fluidity and balance in its musical presentation. The trebles are very smooth, not irritating. Bass is deep and controlled without losing any of its visceral impact. Sound imaging is more subtle in comparison to the Pocket Reference, but once again, more accurate and controlled. Overall, the smoothness and resolution of the HR-2 definitely makes it the superior of the two. The darker presentation is more of my personal preference.
Pocket Reference is very, very exciting and punchy. Trebles seems to be more extended, with a little less control on sibilance (nevertheless very good control, just not as well as the HR-2), and bass is deep and punchy. Everything has a more exciting "kick" to them. The extra kick in the sound also gives it more of dimensionality in the way sound imaging is reproduced. Overall though, you can tell the sound is less refined, but nevertheless very, very good.
Which brings me to another conclusion.. I really do like the PR much, much more than the XP-7. XP-7 with AD797 opamp sounds like the HR-2 in many ways.. but it definitely doesn't approach the superiority that is obvious with the HR-2. I've never had a XP-7 with a power supply, so maybe the difference in using the power supply versus the battery would bring it closer to HR-2's level. However, right now I'm very happy I went with the HR-2 instead of the XP-7. Of course, this is being very nit-picky.. but at this level of audiophilism, you have to be, right?
I would take Pocket Reference over XP-7 as my portable amp, because of the versatility (recharges battery when plugged in), consistency (doesn't sound different with AC adaptor or battery), no need for an external power supply. The sound is "different", so it's hard to compare it directly in lineage with XP-7 and HR-2.. but I definitely feels that it brings something different to the table than the XP-7... thus placing it as a better choice to compliment the HR-2.
Most of all, I'm still very, very impressed with 2X-S's performance. It is definitely on par, if not superior than my CD3000 in many, many ways. (Well, all things other than soundstage)
