Review: (5/5 stars)
Nice upgrade!
Here are my opinions of these pads, after a month or two of ownership.
They are currently on a set of AKG K550 headphones. The circumference of the K550's are a bit larger than the upgrade pads. It took some stretching to get them to fit. The pads are tall and they help with the headphones clamping. They are firm yet comfortable and can be worn for extended periods of time without fatigue. The velour is nice because they do not trap too much heat. The foam and velour is breathable so your skin won't sweat.
Take note that they will change the sound of the headphones they're on. They have seemed to reduce some of the bass, because of this, the headphones became brighter. The K550 have some bass emphasis so the pads have served to flatten the response curve. If you prefer more bass in your cans, buy the leather version. I enjoy a flat curve which allows me to discern details such as quality of recording, sound engineering, quality of instruments, etc. A good recording of an orchestral piece is absolutely amazing with the upgraded K550.
The soundstage has also widened since these pads are taller than the stock K550 pads. The angle of the drivers are adjusted because these pads are angled. The stock pads make the driver angle to be perpendicular to your ears. The angled pads tilt the driver angle so that they're parallel to how the ears are shaped. This makes it feel as if the sound is coming from in front of you, rather than to either the left or right channels. I like this effect because it feels more natural, as if you're in the room with the music source and they are right in front of you. This has helped immensely with my counterstrike as I am able to better pinpoint footstep locations.
The velour does attract dog fur, so have a lint roller on hand.
Overall, I am happy with this purchase. It's an inexpensive upgrade which will dramatically change your can's characteristics.
see less
By
Amazon Customer on October 17, 2015
