Review of the Little-Dot MK1 Portable Headphone Amplifier
May 22, 2009 at 6:53 AM Post #256 of 264
based on your review, the MK1 might be limiting the soundstage. Some hfiers have favored the T4 because it's a 4-channel architeture amp which will give a more 3D effect. Not sure though if this is relaible as I have yet to buy a T4. but I do agree with you on th vocals. PFE is just very good with vocals and minute details of music.
May 23, 2009 at 7:25 PM Post #257 of 264
Agreed, this is why I am now looking for an opamp that will increase soundstage over the LT1364. Maybe the stock opamp was wider but I will need to test it out and find out.
Jul 15, 2009 at 8:08 PM Post #258 of 264
Hey there,
I'm also interested in Little Dot's MK1... but I am curious if anybody was able to compare the MK1 and MK1+ so far?! In my opinion those two are entirely different amps and I don't know which one is "better".
AFAIK those are the specs...
MK1:
  1. LM4562NA (DIP8, socket)
  2. TPA6120 as headphone-amp
  3. 4x3,7V power supply
  4. Gain 2,4,8
  5. aluminium enclosure
MK1+:
  1. LN4562NA for "Normal" version, 2xLME49710HA for "Gold" version (TO-99 package)
  2. LME49600 as buffer
  3. 2x3,7V power supply
  4. Gain 1,2,4
  5. aluminium enclosure (only the "Gold" version)
On paper both have their advantages, but how do they compare in terms of sound?!
best regards,
bearmann
Sep 6, 2009 at 6:14 PM Post #260 of 264
My LD1's battery won't hold a charge I thought it charged up Ok but when I switch it on there's no charge at all (and no blue light). I've had it well over a year now, so what are my options, where can I buy a replacement battery (if that's all the problem is).
Strangely (and annoyingly) I also found my Marantz CD-63 that's been going strong for years now won't switch on.
...and one of my Koss KSC75's has lost the right channel
Oct 5, 2009 at 9:20 PM Post #262 of 264
* BUMP *
My LD1's battery won't hold a charge I thought it charged up Ok but when I switch it on there's no charge at all (and no blue light). I've had it well over a year now (ordered 30th Jan 2008), so what are my options? Can I just buy a replacement 3.7V 500mAh battery (if that's all the problem is) or should I email David (jasmine_chine) direct?
Anyone?
Jan 15, 2010 at 3:35 PM Post #263 of 264
I think David told me once that the battery should last three years or so in my LD MK 1 +
I asked him then what...do I replace it myself. He said I could but it was a little tricky as the battery is hard wired. He told me that I could send it back to them and they'd do it for me.
Jan 17, 2010 at 9:53 AM Post #264 of 264
Little bump there but yeah, for future owners definitely contact David ASAP if the problem occurs, he is very quick at replying, provided you're in relatively the same time zone. He is very helpful too and will be glad to take a look at the amp for you
