I currently own the CK9LTD and have comfort problems with them, since these are effectively the same design it would be folly of me to engage.
Ahh. The CKR 9Ltd. Hahaha, I have that too and I understand what you mean.
CKR 9Ltd might be only model in the CKR series in which the stock eartips actually sound better than the JVC Spiral tips because of the slanted input instead of straight.
It seems the stock tips were pretty much meant for CKR 9Ltd and not really for the CKR 9 and 10, which makes sense because the Ltd is their limited model so they tried to fix their mistakes.
In fact, I would argue the stock tips on CKR 9Ltd sound far better than the JVC Spiral on the CKR 9 and 10 even though the stock tips were probably just some left over tips from another AT earphone series.
That said, for me, while the left ear fits in perfectly, the right side... is a bit weird.
I have no idea why the sides slant to the other side of your ear on both sides. It is rather annoying with single flanges sometimes (unless I get that 'good' fit).
The solution I found was:
Get a double or triple flange eartip.
The sound is worlds apart from the Spiral dots, Comply, SpinFit, stock tip (by the way, I found the stock tips to be best of all those single flange tips on the Ltd model simply due to its differing shape). For specifically the CKR 9 Ltd, I highly recomend double flange eartips (or triple if available).
The main reason I feel the JVC Spiral sounds 'better' is because of its size. That's really it. The dots are wayyyyyyy too small to do any real justice on the sound difference.
In fact, what I have come to learn after maturing as a listener recently is the larger and longer the stock tips, the more it sounds better in usual (as it goes deeper inside your ear).
Try purchasing some medium size double/triple flange. For me, I am using the Yamaha EPH-100 double flange (small though I use medium small for the EPH 100 which is weird because my ears are at least medium on every other brand tips).
Seems like even after all this brainwashing of "spiral dots" or "spin fits", the EPH-100 double flange tips to me has no competitor in sound and comfort.
Of course I don't know your situation but for me, the double flange eartip solved the issue for CKR 9Ltd. The sound with my Yamaha EPH-100 eartips and the stock/spiral/etc tips are night and day.
I honestly don't understand why more people don't reserve to double or triple flange eartips. Once it gets "drilled" to your ears, it seems far better at sending the sound directly to your ears.
If you actually look at the model differences between different stock tips (I completely failed with the Shure Olives eartip and no idea where it is right now):
Here in the image are the various (and far more) eartips that were mentioned in this thread. JVC Spiral dots, what not!
As you can see, the EPH-100 dual-flange eartip is abnormally long. And the inside is COMPLETELY hollow. It is pretty much a straight double flange barrel (with the length of triple flange). In other words, you get literally the 'full' sound of the earphone most directly to your ears resulting in the best sound I could reproduce with the CKR9 Ltd. Also, the sound stage becomes (quite frankly) a 100 times larger as it is no longer all squished on such a small output hole but rather directly straight to your ear from a barrel like tunnel
If you can find these kinds of double flange barrel shaped eartips, I highly recommend with the CKR 9Ltd. The slight tilt on the top of the earphone makes double flanges such as these SUPER comfortable. Just a word of note though: i had to use a size 1 smaller than I usually use for the double flange. It might vary from person to person but do take note of that. (at least with the EPH 100 eartips)
That said, I know those eartips have been never mentioned as Yamaha has never sold replacements of the eartips meaning most headfi listeners won't have that type of eartips. In fact, I can't think of any other company other than Yamaha that has a long barrel shaped double flange that is super comfortable and well made (the rubber seems to also feel the best out of all the earphones people listed). It really puts the JVC Spiral dots and Spin fits to shame at least to me with the CKR 9Ltd.
So to those having trouble with fit issues with the CKR9 Ltd, try grabbing a double flange eartip! Unfortunately for triple flange, I realized even on Amazon I cannot find the size necessary to fit my earphone. Comply says the size is 400 and I have yet to find a triple flange that fits that '400' size :/. I was rather disappointed the MEE triple flange were 200 though I think one of its double flange models are 400.
