@ rgs9200m
Your questions:
3. Meaning of the different gain switches
Due to the very low internal gain of US 4+ (-4 dB for unbalanced operation / +2 dB for balanced operation) it is neccessary to preparea high amount of gain in case of low level input sources combined with low efficiency headphones.
This is achieved by 2 x +12 dB gain, giving +24 dB gain as a result.
All three light-on-dark switches are acting around the input circuitry
while the dark-on-light switch will push +12 dB gain inside the power amp circuitry.
By combining these switches eight meaningful gain settings are possible to cover virtually all sources and all headphones
whilst maintaining lowest noise and maximum attenuator travel - these are : -15 / -12 / -6 / 0 / +6 / +12 / +18 / +24 dBr
Thank you, Fried
I'm a lawyer, which probably explains why I have difficulty trying to wrap my mind around the technicalities.
But I was wondering what the difference is between gain and amplification.
Am I correct when I say gain is about voltage and amplification about current?
Seems like by keeping the amp section as pure and lowest noise as possible, more parts are needed in the gain (preamp) section to compensate for that? Is this a better place then for the signal to be manipulated?
Makes me think that an even more improved ultimate US4+ doesn't have the relay volume control at the end in the amp section, though controls the volume solely through the gain in the preamp (which for some reason seems to be chosen as the better option now too for the US4+, be it only 8 volume settings are available.
Or I could be plainly wrong, oversimplifying things like this.
John,
@project86, I thoroughly enjoyed reading your review, as usual. Thank you for your splendid efforts that will serve as a little amp encyclopedia to me for quite some time to come.
Have you had a chance to hear the Benchmark HPA4 by now for some comparison with the US4+? I'm quite curious as I keep seeing good impressions popping up on the former.
Thanks!
Stijn
