SliceOfPierce
- Dec 9, 2014
Anything you suggest in the under $50 range
JVC HA-FX1X ($25) has plenty of tight bass without the harsh treble (a bit recessed actually), but it is amazing for the price range.
I'm pretty sure you can snag the M-DUO for about $50 (or less) fairly regularly. MEE also have a few single-driver IEMs on the market, which - for their price - do better than expected, such as the M6P and M9P, both of which are <$30. Those work well for bus/train commutes, and you won't feel bad about these marinating in your gym bag between workouts.
You could also do a lot worse than Sony's MDR-EX100AP, which you can pick up for about $30. They can be fun sounding without being too fatiguing. They're a great upgrade over included phone-buds, and do well if you're an on-the-go listener.
Quick note: The above recommendations' weakness is the mid to treble range; mids tend to be recessed with bass reaching up into and cluttering it, and highs are either dull or a bit harsh (but never both). None of these traits may bother you, however.
Explained better than me haha
Sometimes I feel a little "closed in" with these due to the recessed mids, but I can highly suggest them for your taste and budget.
And they do have an overall "fun" sound that I always enjoy listening to with music that better suits them.
... and something I noticed was that the treble was, to me, sibilant ...
I actually just "burned" them in for about 12 hours, and it's really tamed the sibilance. I've zeroed out the treble on my X3, and what I heard yesterday seems gone. Others have said, too, that Comply foam tips help tame the sibilance too. I have a set that should show up tomorrow, so I'll report back about it. Right now, I'm using the bi-flange tips.
Well, I can definitively say that Comply Tsx400 tips tame treble, and increase bass response. It WILL shake your brain. At least with the Fiio X3 and the bass turned up to 10. It really is an incredible experience.
