DougofTheAbaci
- Apr 20, 2007
Thanks for the info - I'm going to go for the 2 pin, but not sure about the vocal, music or bax...
BaX seems to be the model of choice so far for people.
Someone else mentioned a loose fit on their Sure's.
That would indeed put me off too.
The 2-pin version I have needed (very) slight 'squashing' of the pins on one side to fit snug, but it's fine now (my monitors were originally built to a very slightly different pin size).
I'm looking forward to trying Linum's own connector on my next CIEM's, it sounds like it might be a big improvement over current connectors.
Sonically, my impressions differed, boosted bass, slightly more 'V' shaped overall.
I think I'll try the music model next time as I don't think I'll be going balanced any time soon.
Sorry to hear it didn't suit your purposes.
Would I be right to assume that your sleeves are silicone?
Do they alter the sound of the 846 at all?
(just curious, sorry for brief OT)
HA! now THAT'S what I call an answer!
Cheers moedawg, I'm pretty envious of your setup
Out of curiosity, how are people using these that they think the cable isn't long enough? Are you talking when set up with an AMP on the desk or portable? Because I've kept mine both in my pants pockets as well in my inside breast pocket on a few jackets, I've never had a problem with length. I'm also not exactly a short gentleman so it can't be that you're all seven foot giants...
I could see it being a bit of an issue while in a seated position if your AMP is exceptionally far away, but I'd just say get an extension cable or something. On the go the last thing I want is a huge mess of cable (that will only get more tangled).
I have used this cable for about a week now, together with an ibasso DX90 and SE846 iem.
Soundwise it is a bit dampened or darker than the stock cable. The highs are not as sparkling and voices are somewhat drawn back. At first I wasn't too happy abot it, but now I'm not so sure...
