[REVIEW] DUNU Ares and Crius
Sep 22, 2011 at 11:40 AM Post #16 of 24
hi clieos
donno if this already was asked. can you compare the Ares (and Crius) size(s) with the Xcape IE or Xcited?
i got the Xcited and i found them longer than the Re0. not much but enough to say that the Re0 are comfortable and i can get a good fit , and the opposite with the sunrise
thanks
Not sure if I can be much of help here as the Xcape IE and Xcited I have are both using the old housing. The new housing is slightly different so I am not sure any comparison on size will be valid at all.
Sep 22, 2011 at 11:44 AM Post #17 of 24
you mean this one ?("stolen" from joker's review
Sep 22, 2011 at 12:48 PM Post #20 of 24
Actually the housing of RE0 / RE-ZERO has been changed as well.
Anyway, the old and new housing of Xcape IE / Xcited seem to look similar enough. Here is a picture of old housing vs. Ares and Crius.
Sep 22, 2011 at 1:04 PM Post #21 of 24
fantastic! thanks a lot!
the crius seem to be close to those sunrise , wider in the middle (on the red/blue ring). but the ares are just giant! if the xcited didnt work i bet the ares much less
didnt know the Re- housing also changed...
Sep 23, 2011 at 3:54 AM Post #22 of 24
ok, then. seems the Dunu wont fit me much better.
now. having the pl50, getting a very good fit and comfort, and a decent seal (with a lower isolation level). do you consider the meelec A151 will be an important upgrade SQ-wise, keeping the fit/comfort factor (and isolation) ?
Sep 23, 2011 at 4:14 AM Post #23 of 24
SQ - yes; fit / comfort - obviously more personal, but a yes for me a well.
