project86
- Feb 21, 2007
What's your ergonomic issue with the Magnus cable again? I should know but I seem to have forgotten. Was it the memory cable section?
Yes, this cable is constantly used with the 8.A in my home rig (I don't really like taking them on the go - too nervous about losing them).
So far no issues with turning green. I'm very familiar with the stock cables and their color change tendencies - I got the JH13 FreqPhase a few months back and the cable is already pretty green on one side. Didn't take long at all. But the 93Spec is still showing no signs of it. Does that mean it will never happen? I couldn't say for sure.... but it definitely resists it better than the stock cables do.
I've been looking for a new cable for my 8.A's and I think this is going to be it. There were a list of things I want to improve on them but only by the slightest degree, things like bringing the vocals a bit more forward and fleshing out those highs a tad. Sounds like this cable is the perfect solution to both my ergonomic issues with the Magnus and what small sound issues I have with the 8.A. Do you find you use it as your primary cable with it or do you use something else?
Oh, other question: I bought a stock clear cable, think it was a Westone, and it's started to green a little in certain spots. I'm told this is consistent with clear cables. Did this happen to your 93SPEC? This wouldn't be a deal-breaker, or necessarily even a negative, I'm just curious.
