lindrone
King Canaling
- Aug 25, 2003
Heheheh.. as good of an analogy as any
Well, you're missing the key point... the reason why I brought it up is not to track down why ER-4P sounds worse than ER-4S in terms of detail.. but the "reason" as to why that happens.
The important issue is that ER-4P and ER-4S has absolutely no differences in their driver design whatsoever. The only difference is the resistor used in the y-joint, hence shaping the sound differently. This is also the reason why you can get a P=>S adaptor, which is simply a resistor that adds the resistance to match that of the ER-4S.
The decrease of the resistance allowed the driver to be more "active" by picking up more bass resonance as well as other resonance, which in terms will increase the perceived decay as well (since resonance is a part of the equation). Which in term also made people think they sound muddy as well. Overall though, ER-4P was a retrofit of a finely tuned earphone for its specific purposes, and retrofit never work quite as well as what was originally designed to do certain things.
This goes to prove the point that sound shaping can easily be done using a variety of methods, as simple as presenting extra resistance in the signal pathway will change the sound signature. Which also means such issues as decay can be controlled using a variety of methods as well.
Another interesting point. 2X-S's decay is longer and more detailed, textured than the UE-10 Pro. However it doesn't really drag on all that long in comparison to say.. Sennheisers. So the relative speed is still pretty fast. Although in reality, I don't think either UE-10 Pro nor 2X-S is as fast a Grados driven out of Gilmore amps.
Usually increased decay will always relate to the headphone sounding "slower". Not enough decay will make it sound unnatural.. it's a game of balance.
All a matter of perspective... I think they're too dampened, but they still have more decay than ER-4S.
Originally Posted by random person From both your descriptions I'm inclined to think of the UE10Pro vs Sensaphonics discussion the way one might think of fine chardonnay. There is the lean, tight, "minerally" quality of really fine French wine which many would argue is the best chardonnay in the world, the cleanest-tasting of them all. Think of French chard as the UE10Pro. Then there is the American school of big, oaky, buttery chardonnays -- warmer, more complex, arguably more drinkable, thoroughly engaging. Think of the American chard as the Sensaphonics. Both are gorgeous. Some of us may have a clear preference for one over the other at all times; others of us enjoy both depending on the mood and the food. But they can be equally great. BTW I had a wierd dream last night. My beautiful translucent blue UE5cs were turning clear right before my eyes! WHAT can it mean!!?? ![]() |
Originally Posted by Max Minimum Oh, forgot to mention that I think the loss of some of the detail from 'S' to 'P' is due to the increased bass which is notorious in driver systems for causing chaotic harmonic resonances. |
Originally Posted by Biggie Just curious, how does all this talk of decay fit in with notions of speed and prat? |
Originally Posted by gorman Then again, maybe UEs are too dampened? It's certainly not what I hear with my ears but... one has to be open to everything. |
