individual6891
- Dec 28, 2004
The hole matchings will be all fixed by the time the design goes to production.
Can't change the engraver sizes, because of the large range of text sizes I've used, would look mightly strange if I change it now. Total of 3 tool changes, but nevermind.
Regarding the cavities, do they really look that bad? Got any pics? If they really look quite ugly, I might just scrap them and use an engraved circled instead...
Originally Posted by Sovkiller If you want to save even more, IME avoid the change of tools, that means try to use the same engraver for all the figures. A suggestion based in my experience with them, try to reduce the amount of cavities there, they are not done so perfect IMO, and does not look sharp, just leave the ones that will be covered by the the knobs or the ones that are small, and why not removing a few? This will make a more sober design. Also check the coordenades for the cavities and holes, they should match exactly, if you look closer there are some crosses that does not match and are overlapped (check bassboost and output) the on/off on the bassboost the crosses should be in the center of the text to make them look symetric... But don't pay too much attention to me, I'm a little "picky" and "neurotic" with the details...LOL.... |
