Replacing a HT subwoofer with a car sub.
Jul 11, 2004 at 4:40 AM Post #77 of 89
Not sure if this is what you mean....
Jul 11, 2004 at 9:15 PM Post #78 of 89
Does your manual say anything about the receiver's crossover? If it includes an actual high pass on the sats and a low pass on the sub, you can go with the internal x-over vs the one in the sub. In order to do the phase check that I described above the receiver crossover needs to be disengaged (allowing full range to both the sub and the sats). Once you have the phase nailed down, you should start with the 100 hz setting in the receiver. Leave the sub set at 160 if the receiver has a low pass on the sub channel. If you are getting a lot of cone motion in the sats, go to the 120 setting. 80 is probably too low for the 4" woofers.
gerG
Jul 11, 2004 at 9:39 PM Post #79 of 89
Here is what the manual says about the crossover
Adjustable Crossover (80/100/120 Hz) for Bass Management
This setting allows you to set the crossover frequency for your
speaker system. This setting is valid when “Subwoofer” is set to
“Yes,” or for speakers that are set to “Small,” at the “Speaker
Config” menu. The crossover frequency is the minimum
frequency delivered to a speaker and can be set to 80 Hz, 100 Hz,
or 120 Hz. Frequencies below this are cut from speakers set to
“Small” and sent to the subwoofer (or to speakers set to
“Large”).
The manual can be found here if you are intrested
So should I just keep everything where it is at with the 100 Hz crossover on the reciever?
Jul 11, 2004 at 10:03 PM Post #80 of 89
I would say yes, set the receiver to 100 hz and the sub option to "Yes".
The sub's built in crossover should be set to 160, since you are not using it.
This is a nice option for anyone setting up a system with a sub. I don't know if it is a common feature in digital receivers now, but it sure makes life easier.
gerG
Jul 11, 2004 at 10:06 PM Post #81 of 89
I think it's a pretty common feature for receivers nowadays. My friend has it in his Onkyo that he got for under $300, I think, and I'm sure cheaper models have it as well.
Jan 11, 2005 at 12:34 AM Post #83 of 89
Well, after some months of use, it still sounds good.
However, I want to see if I can push it even more. Can anyone recommend me a new driver (from parts express if you can) that will work good with my box and port dementions.
Jan 11, 2005 at 1:20 AM Post #84 of 89
Well, I can't help you there, but I was toying with the idea of building an isobaric with this woofer
http://www.partsexpress.com/pe/showd...number=295-190
Jan 11, 2005 at 2:14 AM Post #85 of 89
I have a cheap Awia 10 inch 150 watt Home Theatre sub. Instead of buying a whole new sub, I thought I might just change the speaker. I got the sub apart and pulled out it out. Would it be worth the extra 50 bucks to buy a new cone/driver and put it in the case with the home theatre amp?
Mods: Can I get this thread moved to DIY maybe?
Find out first with he manufacturer of the driver you choose, sometimes the subwoofers designed for car use, are designed just to work properly in small volumes, as the interior volume of a car, but once you place them inside a bigger space (as a room) they do not offer the same performance, do not mix apples and oranges...but in general you could always get a better replacement, for your sub, choosing among the driver manufacturers, you may need ot know some of the parameters first....
Jan 11, 2005 at 2:23 AM Post #86 of 89
Oops, sorry, I probably should update my first post. Instead of replacing my current sub, I went ahead and just built a new one from scratch. Now, months later, I want to upgrade it.
Jan 11, 2005 at 2:36 AM Post #87 of 89
What size are you looking for? Parts Express, Madisound, Speakercity, etc...have a huge selection...try also Adire, they are among my favorites, if I need to go again into that, a Titanic or another Shiva (or better) from Adire would be my choise, as for the amps you have a bunch in the PartsExpress page, and in Apex Jr (this guy sometimes show up with really good stuff)
Jan 11, 2005 at 3:49 AM Post #89 of 89
Here is a good example of the Adire in action, and compared with other drivers of the market, they have evne a video...I'm a fan of those guys, at the time I got mine it was one of the best drivers available for that price....
Here for 20.00 more you almost double the power, nice amp, be prepared for a good box OK?
But if you do not have the extra cash to blow, the Part Express one, is a very good choice, but why not the Dayton Titanic instead it is 12" also....just double check it....
