skiguy411
- Jan 1, 2004
I have a cheap Awia 10 inch 150 watt Home Theatre sub. Instead of buying a whole new sub, I thought I might just change the speaker. I got the sub apart and pulled out it out. Would it be worth the extra 50 bucks to buy a new cone/driver and put it in the case with the home theatre amp?
Mods: Can I get this thread moved to DIY maybe?
Ok, update: Instead of replacing the the driver, I decided to build a brand new one from scratch. Dimensions are 17.25 x 17.25 x 17.5 with a 24.5 inch long 4 5/16th diameter port. New question is what is the next step to take in order to upgrade the sub.
