Replacement tube's question
Mar 21, 2023 at 9:58 AM Post #46 of 47
Thank you for the update that's good to now It gives a nice alternative. I wonder what caused the problem with the first try. Glad you sorted it though :beerchug:
Yes, definitely glad that it's solved now. I need to do comparisons to the 12au7 tube and see how noticeable the differences are.
I am pretty sure that air somehow got into the first 12au7 tube I was using. The tube would glow purple for a few seconds and then it eventually stopped glowing. No audio either. I am not sure how it happened, but I would assume that it happened in the shipping process.
Nov 14, 2023 at 3:34 AM Post #47 of 47
greetings
i got a tube amp
Vacuum Tubes That Can Be Used​
ECC82, 12AU7, 6AU6, 12AY7, 13D8, 6AU6, 6GU7 or 6072, 6CC40
can someone recommend a tube that offers a rich organic tubey sounding tube that has
1- best bass in quantity and quality
2- gives great power
3- warm and tubey sound
i have used sophia tubes and feels it lacks richness and bass
