Replacement pads for Ultrasone HFI-2200. Will 2500's work?
Jun 28, 2008 at 2:47 AM Thread Starter Post #1 of 4
rodneymjones
I recently traded for a pair of HFI-2200's. The pads are in need of replacement. I'm not a huge fan of the color, so i was wondering if anyone knows if the pads for the 750's or 2500's will fit?? Also, the pad on the top of the headband was missing. Does anyone know where I can buy a replacement?
Thanks for any ideas you've got!
Jun 28, 2008 at 4:39 AM Post #2 of 4
iQEM
Indonesia
i guess it's fit perfectly, since they both using the same metode for pads removal...CMIIW !
Jul 3, 2008 at 12:58 AM Post #4 of 4
rodneymjones
I got the scoop from a rep at Ultrasone USA. Both the 750 and 2500 pads will fit the 2200's. The pads for the 750 are velour on the outside and pleather on the inside for better isolation. The pads for the 2500 are all velour.
Thanks for the link for the headband pad, Leto A.
