Replacement Pads for Sennheiser HDI 234 Wireless Cans - Orginal or Equivalent (Pic Included)
Apr 10, 2011 at 11:52 PM Thread Starter Post #1 of 1
insultcomicdog
Hey All,
I'm trying to find replacement pads for these cans Sennheiser HDI 234 Wireless Headphones.
Here's a pic:
http://instagr.am/p/CoCRu/
They're pretty old (early 90's?), and I'm 99% sure Sennheiser doesn't stock replacements for these anymore. I've looked on eBay and the web but haven't had any luck.
The outer diameter is 90mm and the inner opening is 50mm.
Are there any local shops in Toronto, that would carry original or equivalent replacements? I just need something that fits, b/c other than the rotten foam these headphones are perfect.
Local would be great, but an online store works for me too....
Best Regards,
SMJOHN
