jimbobuk
- Aug 11, 2002
Hi folks,
I just got my 2nd pair of K1000s.. they are in fully working order which is a nice relief. Got the AKG branded SAC amp too which is working well, i understand now why its all heatsink, it gets pretty hot!!!
Anyways the pads on the K1000 are fairly used such that they are much flatter than my newer fresher pair of K1000 (with probably less than 20 hours on my head) I was wondering if the temple pads are easily replacable.. Mainly so that i can stop the bottom of the headphones + wire gently touching the side of my face compared with being held away enough with that extra 1/2cm of a fresh pad.
everything else looks great, the headband looking more difficult to swop out and with no obvious problems i'm happy for that to stay as it is.
Anyone got any ideas
Regards
Jim
Regards
Jim
