longtalltechsan
- Jun 2, 2014
Hello all,
First post here. I recently got a pair of Klipsch S4i ear phones. I ordered the S4i II's but they screwed up and sent me the S4i's. Not a big difference except for the cables. To compensate me for their mistake, they gave me $20 back. So I have kept them since the sound is supposed to be the same, with the only difference being the flat cables.
Anyway, I did about a 40 hour burn in and noticed some difference. In some places I listen to them, work, home, they sound pretty good and I am happy with them. However I also wear them when working out and they don't seem loud enough. I have also put some of the Comply TX100 tips for maximum sound isolation. They work and I can hardly hear any outside noise. I'm just not sure I am completely happy with the sound, especially as I would like a little more bass. I have also run into a few songs where the bass really distorts. It could be bad rips, but not all that likely. I'm also not real crazy about what seems to be crappy build quality and they seem really delicate.
I am considering getting another pair, something $100 or less. It would also be nice to get some that use the same Comply tips since I bought 2 packages of those and would hate for them to go to waste.
Right now I am looking at these as replacements:
-Shure SE112
-RHA MA450
-Ety MC3
-Meelectronics A151
Any others I should consider? I read about the Shure SE215 but have read that they don't have a lot of bass. I am not hung up on having controls for the apple products, although it would be nice since I typically listen to my iphone or ipod when working out.
As for the type of music I listen to, I listen to a wide range including classical, country, rap, metal, rock and pretty much everything in between.
Any other suggestions I should look at?
Thanks in advance.
-Shure SE112
-RHA MA450
-Ety MC3
-Meelectronics A151
Thanks in advance.
