Replacement cables for hd 497
post-1434335
Thread Starter
Post #1 of 4
imported_Echo_
where can i buy some mine brock right where they connect to the headphone
post-1434556
Post #2 of 4
XBTed
In the Berlin area, via Lawrence, Kansas
From my experience, nobody carries those cables in stock, since they have to order from the same people we do they figure it's not economical to stock them due to mark up. I tried to order one directly from Sennheiser, but they always seem to be out of stock, so...
I made one with parts from radio shack. If you have a soldering iron and a dremmel tool, then you can do it with about $10 in parts. If you need any suggestions or help if you want to take that route, let me know.
If it broke where you connect to the headphone, then you could probably just solder a new mini-plug on the end of your existing cable, that would be super easy and even if you have to buy a soldering iron, it would cost less than buying a new cable.
post-1434883
Post #3 of 4
PTheD
Irony indeed, nobody carries them and Sennheiser is out of stock.
post-1434892
Post #4 of 4
sbulack
I just went to:
http://shop.sennheiserusa.com/retail...ct_prod=083380
and added one of the HD497 cables to a shopping cart. I don't want to buy one, so I didn't check out, but the replacement parts web page isn't saying "Out of Stock". I recently (April, 2005) bought a few of these cables for my daughter using this link. If you're interested in one of these cables, it might be worth your while to try ordering one using this link.
