rkw
Using which headphones?The audio out of the iPhone actually is as good as with a separate audiophile DAC. I've compared the output of my iMac and iPhone to the Oppo HA-1 and I can't hear any difference at all.
I think in the next ten years we’ll be streaming lossless files on very high quality wireless headphones.
They assume the audio quality on their phone is fine, when it could be so much better.
Can't WAIT!! lol
Define "better". 1%? 2%? If its worth it to you, go for it. Most DACs these day are totally transparent, its not 1998 anymore. Well, for 99.999% of people, I'll leave the superhuman audiophile out of it, of course they can hear it.
It's not just about the DAC though. The limitations of wireless connections are still apparent to much more than 99.999% of people, and that's not including those with Golden Ears.
Agreed. BT audio is not very good. Still good enough for its application, ie small bt speakers, easy background listening, phone comm, all that. The APT-X is pretty transparent though, really. Audio over IP is the way to go though.
Maybe I didn't read enough, I do mean DAC -> (amp) -> wire -> driver.
If you’re using Apple Music or iTunes anyway any Bluetooth headphones that support the AAC Bluetooth codec will sound as good as they do wired with those files.
I dunno if I agree. I downsample ALL my CD-Quality & Hi-Res purchases to 512 kbps AAC because I can't tell the difference vs. lossless FLAC/ALAC files. Nether can anyone statistically-speaking. Having said that, I tried comparing a wired connection using a FLAC Hi-Res file to a Wi-Fi connection (yes Wi-Fi, not BT lol), which has has like 11 times the bandwidth of regular BT, and I did notice a slight difference still. So I'm very hesitant to believe that it sounds as good as wired.
AAC via Bluetooth is transmitted at 264kbps on an iPhone, which may be why you're able to hear the difference since you're using 512kbps files.
Which headphones have both a Wifi and wire connection?
