dknightd
- Jan 3, 2002
It does, thanks. I assume the loop through option
just puts the output in parellel to the headphone
amp section?
I guess that would be easy to do with any head amp, drill a couple of holes, pop in some RCA jacks, solder some copper wire between them. Done.
Or maybe some RCA "Y" cables
I'm still not sure this will have no effect on sound quality. After all, I would effectively be putting two parallel loads on the preamp. Wouldn't
adding an additional load effect the sound?
Originally posted by danny dnighted, The loop through option for the Headroom Home, MOH, and MAX amplifiers is a simple copper connection inside the unit between the two RCA connectors. It should not degrade your signal at all to the amp. This is different from the Line out on these amps, which is buffered.... Hope this helps |
amp section?
