Redcarmoose
I have submitted a ticket with gearbest, and already got an answer where they asked if I'd like to have it resent or refunded. I'm not sure what I'll do yet.
I pulled out my glue gun and completely sealed the left earphone. Now i can get a seal, but I'll have to listen a bit more to see if both sides have the same sound now.
Maybe I'll have to do a tiny airport to get similar sound.
I'm a bit interested in the remax 610d as well, so i might take the refund and order that one instead...
That is fully crazy to have that amount of (silicone glue, I guess) fix the issue?
It's also in a place I would least expect would create an air seal issue. Though I know very little about IEM construction. They have the red mesh port which is open on the side which is a grand diversion from most IEMs I have. At best most have a small air-port at some area. But that is a good question, if the front chamber needs to be airtight and could be a sound issue either by faulty construction or post build damage to the cable stress relief?
I have been pretty lucky in only finding one pair of IEMs to be fake and never getting a damaged product from my China brand purchases. Sadly if you read the KZ thread it's really an issue with KZ products. It makes perfect sense as the maker is making mllions of IEMs and selling them for $5 to $18 dollars so quality control can not be that great.
Though I have purchased 4 KZ IEMs and all have been fine. I have also made 4 Remax purchases and they have all been fine as well as the couple of Remax demo models in stores have all had great quality control?
I have the Remax 610s also and they are great but in different ways. They have amazing detail and soundstage but the bass fails to go near as low as the S1 or S1Pro IEM. They have a very open and only slightly V shaped signature much closer to flat that the S1s. Still they are famous for being an exceptional value being as low as $10 in the USA. They are maybe slightly smoother than the S1s and are lacking some of the energy the S1 produce but make up for it in detail.
Also you may try to find the original S1 as I think they have a nicer cable than the S1 Pro? The plate on the side is also solid aluminum and not plastic. The two changes go miles to give off the effect of a more expensive product.
