morgin
I miss the updates from you guys. Anyone tried anything new to get better results?
I haven't made any new measurements in a few weeks, not since the last measurement I posted about here. I still intend to make one with my pair of LSR 308s to see how they fare against my Kali LP-6s that I recently bought, but I've been so happy with my last set of measurements that I've not felt any need to make some more.I miss the updates from you guys. Anyone tried anything new to get better results?
I'd like to have a $ for every time I've thought while listening "I can't imagine how this could sound better." I do think about taking more measurements sometimes, but then I listen again and my motivation evaporates.I've been hesitant to glue them directly to foam since this isn't a reversible modification.
My best measurements were with foam. I’ve tried them naked in my ear and with silicone housing. But the best have been with foam.I've been hesitant to glue them directly to foam since this isn't a reversible modification
Very true! I actually just straight-up prefer using my Ananda's with my latest BRIR over using my speakers now. And not just because I don't have to worry about annoying the neighbors by being too loud. The acoustic problems with my room stick out like a sore thumb to me since I'm so used to listening with a BRIR that has all of those issues corrected with EQ. And my speakers can't produce sub-bass like my headphones can so they speakers seem thin and weak by comparison.I'd like to have a $ for every time I've thought while listening "I can't imagine how this could sound better." I do think about taking more measurements sometimes, but then I listen again and my motivation evaporates.
That's brilliant! I'm going to pick some up this weekend. I never would have thought of that in a million years.A suggestion on the non-reversible glue issue, I used silicone caulk for that very reason. Once it sets it's secure, but also flexible enough to be removed if desired without damaging the mics.
The hot glue also sounds like a good option. I'd love to try making a measurement in an acoustically treated room as well, though I find myself wondering how much of a difference that would really make vs. correcting BRIRs with EQ like I've been doing. It probably would be an improvement but just how much of an improvement would be very interesting to discover.I cut out a little ditch in the middle where the mic would be glued but made sure the mic isn’t flush with the foam. And used a hot glue gun because I find that easily peels off if I need to remove it.
Really wanna try getting a sound treated room to rent to see if that makes a big impact. But need to find reliable consistent recordings first
I actually recently sold the fancy speakers I'd had for years on eBay. My headphones with the Impulcifer enhancement are so much better than listening to the speakers that they became just expensive decorations. All the issues with my room and speaker anomalies I spent so much time trying to tweak have been totally eliminated. And with the speakers I would always be worried about whether my neighbors were home, the time of day, and whether the volume was perhaps a bit too loud. The complete freedom to listen at any time at the ideal volume, and to have as close to perfect sound as I can imagine after seeking it for so long, is more than amazing.Very true! I actually just straight-up prefer using my Ananda's with my latest BRIR over using my speakers now. And not just because I don't have to worry about annoying the neighbors by being too loud. The acoustic problems with my room stick out like a sore thumb to me since I'm so used to listening with a BRIR that has all of those issues corrected with EQ. And my speakers can't produce sub-bass like my headphones can so they speakers seem thin and weak by comparison.
Will you also give your second pair of jbl 305 a try with the more even mic position?
I actually haven't tried the decay option for this yet but I HAVE tried using reverbation management and that helps significantly. The ringing/delay goes away at about 600ms and 700ms for most of the measurements I've run into that have this issue when using room correction through Impulcifer.@Brandon7s
Have you tried if the decay option helps with your problem?
This is interesting and something new to try out do you have a link to this paper?Has anyone made the silicone mold microphones proposed by Fabian Brinkmann? According to his paper, this yields the least inter-measurement variance.
Less than one dollar is great. The Primo Em258 is ten times that price.The mics are bought from a Chinese company called "Yinglear", costing less than one dollar each. They claim that it has 72+dB SNR and flat frequency response. I don't know whether it's exactly true, but it does have an SNR greater than 65dB from my experience.
The accuracy for headphones measurements is a problem at high frequencies. The best way would be to do the measurements at the eardrum with a probe mic. But this is not possible with our kind of microphone capsules.This thread is too long and I haven't read through it yet. I wonder has anyone experienced the loss of precision for high frequency (10k+) measurement? Plus, I do feel very bright in 10k+ when comparing the simulation to real loudspeakers.
Theoretically, doubling the number of averages increases the SNR of the measurement result by 3 dB, and lengthening the sweep signal can do that too. In my experience, lengthening the sweep signal does improve high-frequency accuracy for measuring headphones with Impulcifer **, but I haven't tested that in measuring loudspeakers.Also wanted to ask if it was better in anyway to have multiple measurements and then have impulcifer average them out to get the best results from all recordings?
Thanks, I will give that a try.For me I would say that blocked ear channal measurements sound more bright while measurements with only partial blocked ear channal sound better.
