It was my mistake. I’m sorry
Seems like even some developers of audio software are misinformed about how Channel: command works. This command is for channels selection only and, as you have discovered it, Channels: do not impact channels order at all for convolution processing.I'm now totally confused.
The sequence of channels after the command. "Channel: " has no meaning at all. --> I'm really surprised by this.
However in my code the channels still seem to be assigned to the correct channels. If I increase the volume in the wav file on the second channel ( FL-r channel) the virtual channel that is effected is R1. But this actually what I want?
Exactly and that only. So, when you are creating multi-channels Copy line, do care about the channels sequence for convolution processing. Or else you configuration for APO will be messed up.You stated that it determines the order in which the convolution processing will occur.
The most "dangerous" command here is Copy:
You have to be very careful with this Copy command, because it creates that channels order to which convolution processing will be applied. Just test it, it's very simple![]()
Can you tell, please, where did you find info about peaking filter applied negatively and positively in the HeSuVi HRIRs? I don't see such filters application on the graphs when open some default HeSuVi HRIR in Audacity. All peaks are mostly positive in the all 14 channels for example, in the default dht.wav. At the moment, I can't insert images from my PC on this forum for some reason.According to the original Hesuvi text and the original track order:
If the Hesuvi text and track order truly work correctly, the result should be identical when input and output are correctly assigned in that order.
- FLL, FRR are Dirac pulses.
- FLR has a peaking filter applied negatively.
- FRL has a peaking filter applied positively.
From my understanding new users cant post pictures but I think you can upload the images to imgur or something and link them hereAt the moment, I can't insert images from my PC on this forum for some reason.
All right, I will look at your loopback measurement further.I created it myself. We can make it directly using tools like REW or Audacity.
While it’s possible to use actual BRIRs or HRIRs, the current discussion is focused on input/output matching. And Hesuvi means just
Therefore, I applied Dirac impulses, as well as positive and negative filters, to each channel for intuitive visualization.
