I'm sad it didn't work for you =(I tried it but it messes up for me. The sound moves to the back and I lose all my surround unfortunately. Dolby access with my HRIR works the best for me I just wish smeone else could replicate what I hear
I need to check a few things.
0. you download from new link?
1. Is it correct that APO inserted upmix.txt over hesuvi.txt?
2. Is your hesuvi gain the same for each channel? ---> Even if the speakers in the room have the same gain, the impulcifer often changes the gain depending on the information in the ultra-high frequency, and most of them have the effect of increasing the gain on the side and rear channels.
It's not implemented until dynamic processing, but it follows most of the logic and most users say it works well.
And that the sound you've experienced goes backwards is something that can happen when the gain of surround/back surround/front/center I mentioned above doesn't match gain.
I've fixed the code a few times before, and it was assigned to the wrong channel with the wrong separation, but in the end it's the story of Side and Rear, and there's no overall movement of the image. So that's why I'm asking carefully.
I also asked test each speakers and BRIR users who use Dolby and auro upmix to do this and I got confirmation from him that it works fine.
also,
---> Which one are you listening to right now? Sound moving backwards is most likely a gain I said, but I don't understand about surround is lost. for stereo, both Surround and backsurround are working.. you mean atmos?
it's not atmos. Does each track listen to separate sound sources or movies like Atmos or regular multi-channel?
###Btw,
Now i'm even implemented a "center spread" function that applies only to the music version and created separate files.
The existing code is width 0, and widths 2 to 3 seem to be the default. Width 5 or more is not used, so it is excluded
