I tried the transform headphone feature for my IEM's using my Bose 700 - it seems to work - the image is extremely realistic but it's severely lacking in bass compared to no headphone compensation and EQing the Airpod Pros to flat.
This was the command I ran
Code:
python frequency_response.py --input_dir="rtings/data/onear/Bose Noise Cancelling Headphones 700" --output_dir="my_results/Bose 700 (AirPods Pro)" --compensation="rtings\resources\rtings_compensation_avg.csv" --sound_signature="results/rtings/avg/Apple AirPods Pro/Apple AirPods Pro.csv" --equalize --parametric_eq --max_filters=5+5 --ten_band_eq --bass_boost=4
I tried adding a boost 10 but to no avail.
I need to trouble shoot more or pick up a pair of decent open backs that can act as a simulator headphone. The DT990 that I have will have too much treble simblance for that purpose. Is there a way I can bake in the EQ compensation from oratory on my DT990s that remove the nasty treble and use that as the simulator headphone? That'd be the ideal headphone for me for critical Impulcifer use.
Edit: I also tried to use the trend balancer with a stereo only recording vs 7.1. The virtual center was much more accurate with the 7.1 recording. The stereo recording felt like it expanded the sound stage around me.
I also compared my headphone compensated Bose 700 recording with no headphone compensation and a flat EQ with oratory as a source. They're very very similar but the treble is more on point with the actual headphone comp
