I'm trying to make my own notes for the room correction measurement process and hopefully help improve the documentation
Can you tell me if I've got it right?
0) Run a regular recording with the binural mics. But do not process.
1) Replace the csv/text with the mic calibration data from MiniDSP's website
2) Select the UMIK-1 in Windows as default and run (I've renamed the default to prefix it with room and with --channels=1)
python recorder.py --channels=1 --play="data/sweep-seg-FL,FC,FR,SR,BR,BL,SL-7.1-6.15s-48000Hz-32bit-2.93Hz-24000Hz.wav" --record="data/my_hrir/
room-FL,FC,FR,SR,BR,BL,SL.wav"
3) Run
python impulcifer.py --test_signal="data/sweep-6.15s-48000Hz-32bit-2.93Hz-24000Hz.pkl" --dir_path="data/my_hrir"
Where I'm confused is how to tell Impulcifer that you've run the room correction recording? Part 3 is just the regular process - if I don't specify --no_room_correction will it by default process the room correction? How will it know the room correction recording file?
