Hello!
Posting here as I am unable to do so in the "Cable" thread.
Some of you may know the small Singaporean company called Alpha and Delta,
I have their AD01 for nearly four years. With time comes wear and tear and so I need to replace the cable, its on the verge of falling apart. Unfortunately, the original is around 45 SGD, a little too much for a cable imo. For this reason I've been looking for a 3rd party cable that would be compatible with the AD01's.
So far, I have found this: https://www.meeaudio.com/CABLE-MIC-M6PROG2-BK/
However, upon its arrival I have realised how ungodly ugly and thick the cable is and in no way does it suit the AD01 (although compatible).
The cable has detachable 2mm dc plug connector pins, pics below.
I am no cable expert and after some searching for compatible cables I just haven't found anything... If you have any recommendations or know/think that a certain cable fits these, then do post below!
Thanks in advance,
J
Thanks in advance,
J
