wavoman
- Jan 19, 2008
Here is what I wrote:
Originally Posted by wavoman:
Thanks, got it! Good point!
That's actually worse for PC Audio folks who want to put a track from some nice SACD into their PC playlist ... for that we need the PCM 24/88.2 !
Originally Posted by soundboy /img/forum/go_quote.gif You're still slightly wrong ... The Oppo 980 will allow the native DSD datastream to be output thru its HDMI output, which can then get decoded by a HT receiver with DSD DAC |
I was trying to make the exact same point as you -- use a fancy new receiver with HDMI inputs to capture the SACD output from the Oppo -- but I see my error: it is in fact the native DSD bitstream that Oppo puts on the HDMI output, not the PCM 24/88.2... Some A/V receivers have HDMI in, so you could use the Oppo to feed one of them with the downconverted SACD signal if that helps.
