Recommendation for tangle-free EP's with remote control
Oct 23, 2013 at 3:34 PM Thread Starter Post #1 of 6
swlondon
I already own a set of A Jays 4 earphones but find that they are too large to fit in my ear canal. I have the Comply foam tips which are great but even then these earphones do not fit snugly into my ear canal and I have to really push them in hard to make them stay firmly in.
So.....what other tangle-free w/remote control earphones options are there please?
Thank you.
swlondon
Oct 31, 2013 at 3:28 AM Post #3 of 6
Where do you live and what's your budget?
Hi there and thanks a lot for replying.
Sorry for the delay but I never got an alert email telling me that someone had replied to my thread.
I live in London. I would say my budget is around £100 or $160US.
What earphones did you have in mind? I have a-jays fours which I really like the look of but the problem with them is that they don't fit into my ear canal very well, the plugs are quite wide in diameter.
Oct 31, 2013 at 2:02 PM Post #4 of 6
I can't give a proper answer.
However, I do suggest to keep an eye on this thread, maybe a few offers pop out you could consider.
http://www.head-fi.org/t/530008/the-eu-deals-thread/255
I like the Etymotic hf3, but the sound might not be appealing to you.
http://www.amazon.co.uk/Etymotic-Headset-Awareness-Control-Earbuds/dp/B007NTFTLG/ref=sr_1_7?ie=UTF8&qid=1383242360&sr=8-7&keywords=etymotic
Shure se215 (doesnt have a microphone) They're big but the nozzle is thin and the foam tips are comfortable. The blue version is a bit more expensive and the sound signature should be closer to the jays and the cable is almost tangle free.
http://www.amazon.co.uk/Shure-SE215-earphone-BLUE-Addition/dp/B00A16BT4E/ref=sr_1_3?ie=UTF8&qid=1383242443&sr=8-3&keywords=se215
Nov 6, 2013 at 2:39 PM Post #6 of 6
