Recommendation for AMP and Hiby R6 Pro
Aug 14, 2021 at 8:35 AM Thread Starter Post #1 of 1
Matthewlawson3
Tennessee
Hi, I have a Hiby R6 Pro and Sennheiser HD 650 Headphones with a 4.4mm Balanced Connection and Fiio FH5 IEMs with a 4.4mm balanced connection. Both of those I usually run directly into the Hiby balanced connection port. I have used MQA on Tidal in the past and also have FLAC files from rips and HDTRACKS.com that I listen to.
I am considering purchasing an AMP. What would you recommend to go with those Headphones and the Hiby R6 Pro? Also, with your recommendation, could you also tell me how it would connect to the Hiby (via USB port, balanced connection, etc)?
Would it benefit me or not to have a AMP?
Thanks for your help!
