freeflight
- Oct 24, 2001
This is comforting. Thanks.
Originally posted by aeberbach Consider that if they did add one more cell then the voltage would still only be 8.4V, but then the capacity would be smaller. And the battery would last disproportionately less time, because when voltage goes up current does also. There are some "9V" rechargables around that are really 9V, but it rarely matters. WRT the rated capcaity of all these different kinds of battery, the number doesn't tell you anything about whether or not it can drive a Grado amp or other device, it tells you how long it can do it for if it can do it at all. NiCd batteries are among the most powerful when it comes to delivering high currents - electric model aircraft usually use NiCd in preference to anything else because they can drive very powerful motors at currents of up to 80A. NiMH and LiIon typically can't. |
