Arainach
- Jul 25, 2005
How can you compare buck-for-buck with clearly superior results? That's like saying buck-for-buck a cheap 18-55mm zoom is better than a 24-70 f/2.8 Pro Zoom. Absolutely meaningless comparison because they allow you to do totally different things. Quote:
You don't NEED VR/IS in focal ranges that short. At 50mm on a film body, I can hand-hold down to 1/20 just fine. As you get wider, you can hand-hold exposures for a second or more if you're good.
Originally Posted by xzjia /img/forum/go_quote.gif Sure, but what's it going to cost you the other way around? You're paying for VR/IS for every VR/IS lens you purchase, instead of paying only once for the body and reap the benefit even with budget lens. Buck-for-buck wise the value can't be disputed. |
Besides the fact that you can't get stablized version of fast prime lens in the wide-to-normal range (50mm and under). |
