I've long given up trying not to offend people and particularly in regard to technical discussion. In my view, the easily offended deserve their lot in life.
You just gave another example of a generalization (SACD vs CD) then explained an exception, then at the same time pretended it was invalid. You seem confused. Yes, for a variety of reasons, some SACDs may sound better than other CDs. And, in fact, many people have argued technically that the SACD format itself has inherit flaws that are not present in redbook. This could be debated much further, but not by me, for I lack the interest. If you'd really care to make bold assumptions like "SACD is better than CD (period)", do so in the sources and formats forum and I'm sure the trolls will come out from under the bridge to get your goat.
Now, back to video cables. Your last comment:
Get my lengthy drift here? Just like it's not common for audiophiles to prefer their KTX-4 in sound to the HD600 it's not common for videophiles to prefer S-Video over Component. Rather than researching the technicalities of component vs s-video perhaps time would be better spent researching better equipment that doesn't have poor component output. |
This illustrates rather plainly that you didn't understand (or perhaps didn't even read) my explanation. You could very well have a DVD player with an *awesome* deinterlacer and a component output that rivals the best of DVD players and still have a TV or projector that has an even better one. In this case, s-video still beats component. It would be stupid and naive to assume that because one piece of your gear is very good that you should not consider the other pieces. The inherit advantage ("all else being equal") of locating the deinterlacer in the player rather than in the projector is that it can be done there in the digital domain and thus has more potential.
Another point of contention is that you should consider what your gear is actually capable of doing. My projector, for instance, accepts component video only for deinterlaced ("progressive scan"). This means that if you have a DVD player that doesn't have progressive scan, even though it has component output, that the component cables not only won't look better than s-video, they won't work at all. By contrast, of course, s-video on my projector is always an interlaced input so if you had a DVD player with progressive output AND the deinterlacer in the DVD player is of higher quality than the (very good) deinterlacer built into the projector, then you would HAVE to use component in order to see this advantage.
Again, the same example can be made for composite vs. s-video with regard to three-comb filters with lesser video signals such as broadcast television, etc.
Also, the format of the media must be considered. Laserdisc is stored as composite video. Therefore breaking it out into s-video prior to sending it across is not inheritly better. Again, it depends on both the laserdisc player and the TV.
Reread this until you understand it, or just stop talking about it. Your post offends me too, but likely for a different reason.
