If you can hear sounds without making contact with bone, then it isn't "bone conduction" but is soundwaves via vibrations which is what I am suggesting to begin with.What about iems such as the MEST series? (and others those are just the ones I can think of off the top of my head) I feel like they perhaps make the housing rumble in a way that is audible, even though it's technically not touching your bone. Kinda like you can still hear bone conduction headphones like Shokz even if they aren't on your head.
Maybe the hook x bass is just that well tuned who knows, I just know I haven't heard a planar iem bass that sounds like it (have tried hook, timeless, and s12). I kinda hope it is just a really well tuned planar because that means other planar iems in the future can reach the same level and I don't have to look for ones labeled bone conduction
With true bone conduction you cannot hear it unless it contacts your bone (except for a vibration), and the nifty part about bone conduction is that you don't feel is as much as you actually hear it (your going to feel it locally but hearing it at your ears, though due to the way it is being delivered you feel the vibration on your skin). All that is happening when you use bone conduction is that it is bypassing your outer ear and going straight to the auditory nerve (Cochlear Nerve). This is why it has been used for supplemental hearing aids for many years (since the 40's or so).
You can experiment with this using an old phone (that you aren't worried about possibly burning up the amp section). You just need to take a motor from an electric tooth brush, hook a wire to it, then a connector to plug into the ouput of your phone to the wire. Then you just need a rod that has been hollowed out enough that the drive of the motor doesn't contact it to the point of it not being able to spin a little bit. Once you have done this, simply put the rod in between your teeth and you will HEAR the sound (though as mentioned earlier, you will also feel it locally, but will hear it in your ears).
