Tim D
I got a pornographic memory...
- Jun 21, 2001
After getting the JMT amp and comparing and listening between different phones and jacks, I realize how it reminded me a lot of a Dekert article on speed:
http://www.decware.com/paper15.htm
I don't know a lot about impedance...but it seems that in good amp design a "good" amp is typically low impedance output so that its damping factor is greater, and in essence it comes off as having more "speed" or control.
Anyhow I wanted to see how the DT931's worked with the JMT amp and it did pretty well compared to other entry level low-impedance output amps I've tried, but honestly the DT931's are almost unlistenable with low impedance output "speedy" amps! Also whereas it used to be more subtle in noticing impedance related changes between different jacks, it is extremely apparent to me now after listening to the DT931's for awhile and I can now notice these differences in different headphones and jacks much easier as well.
Anyhow the DT931's I would describe as phones that definitely need a slow down, and one of the few phones I've heard that are like this. Through the JMT amp the DT931's seem too fast for its own good and without a doubt it sounds much better through my higher impedance output Audiosource Amp jack. My MS-1 on the otherhand seems supercharged through the JMT amp and absolutely love the greater speed and control of the JMT amp being muddy through the Audiosource jack. With Ety's it is up to preference and the music of wheter you want more speed/control or a slow down, I haven't honestly spent enough listening time but I think I prefer it with the JMT amp. Interestingly enough I never even noticed impedance changes with most other phones until the Beyers showed me just how much a difference it could make.
I think MOST headphones benefit from low impedance jacks and more speed/control. Most receiver/amp jacks are high impedance outputs. I want to pick up a better pair of Grado's after hearing how much the JMT amp just supercharges Grado's. It isn't necessarily correct to say that Grado's don't need dedicated headphone amps to sound good...at the very least you want low impedance jacks which rules out every receiver jack(Same goes for Senns even more IMO). DT931 on the otherhand is a headphone that might actually sound better out of a receiver jack than a high performance dedicated amp!
In fact I would describe the speed and control of the DT931 on the Audiosource to be on the level of the Grado's on the JMT amp. The DT931 being waay too fast on the JMT, and Grado's sluggish on the Audiosource.
Anyhow I now look at a lot of audio purchases with "speed" and impedance type relations in mind. Cables can be looked at in the same manner in altering "speed" perhaps through impedance as well i.e. silver cables probably have lower resistance giving a brighter more controlled and transparent sound, wheras the opposite being warmer, etc. I also wonder if there could be any DIY amps with completely adjustable impedance.
But like the Dekert article emphasizes, it is important to strike a balance in all components, and picking and choosing between audio components just isn't as easy as getting all "speedy" high performance this and that or you'll just crash and burn IMO.
We even know that Ety's have a very strong relation with impedance, but overall it still seems to be a mystery. It just seems like there is a little more to impedance, and maybe with enough knowledge we can make more informed choices in creating a more synergetic setup instead of one that is more "guesswork" to get the perfect speed/control we want.
