From the Indiegogo comments section, there's this explanation:
Q: What is the maximum power output from the 3.5mm jack in milli-watts into 32 ohms headphones? I do not understand what 2x current means.
A: The 2x current mode is a kind of parallel bridged amplifier mode. EarStudio has two stereo DAC and integrated HP AMP, which means it has 4 output ports available. In the 1x current mode to 3.5mm jack, EarStudio activates only two of them, having the other two remained at idle. In the 2x current mode to 3.5mm jack, all four output ports are activated, being coupled two ports for L-ch, two ports for R-ch.
Each output port drive voltage up to 3.2 Vpp. Thus, for a 32-ohm unit, we can have 40mW/ch with EarStudio. In the 2x current mode, two output ports are bridged/combined to a single channel, we can get the output impedance lowered by half, and as a result, get the better damping factor and slew rate. Especially for a 16-ohm unit, current saturation degrades the linearity, and the 2x current mode gives us the better performance.
