chillaxing
- Oct 12, 2013
Yeah, you want in? Are you in the US?
Yup I'm the US. I'll get in line
wow, voices are so much better!
Any further impressions of the NHR-31? Sounds like it's a significant improvement over the NHR-21. How is this iem for rap and metal if you've tested it with those genres? Does the NHR-31 need amping?
The 31 needs amping less than the 21. It's so much more sensitive and louder at all levels. I'm using the fiio balanced cable and that opened up the sound significantly. They sound good wit everything I've thrown at them, but I don't listen to metal. Rap is glorious on them, with all the bass. Even though they don't need amping, the balanced cable really tightens things up and allows them to scale better. The 21s don't scale well, the bass can't handle it. They are better off unamped.
I end up getting 1More triple driver. I oove it so much!
How's the bass? Is it basshead?
Again, $85 for 1more triple driver is beyond my expectation. Really blown my mind the packaging and the sq! Try it to feel it.
