Raal Ribbon Headphones - SRH1A
May 11, 2023 at 11:47 PM Post #6,646 of 7,885
I am listening to my sr1a with my VM-1a and the new filters with my amp on the CA setting since it doesnt need the baffle compensation and I must say it is very different...more dynamic and fuller....very interesting
May 12, 2023 at 12:45 AM Post #6,647 of 7,885
From Mitch...
Re: your question: The SR1a was measured with open baffle compensation in the circuit, so it is not going to look the same as the raw response I measured without the baffle step in the SR1b. So the attached graph is what is added to the SR1a raw measurement versus without open baffle comp of SR1b. If I “convolve” the SR1b measurement with the open baffle compensation, it comes within 1 dB of the original measurement I made of the SR1a’s two years ago. Says a lot about the quality of engineering and manufacturing of the drivers from Raal. Also, the horizontal scale is different in the two measurement charts. So not exactly an apples-to-apples comparison.
I hope that explains it.
Kind regards,
Mitch
Thank you Mitch and Litlgi74 for the answer.
May 12, 2023 at 3:44 AM Post #6,648 of 7,885
I don't have Mitch's filters but have been through many iterations of my own filter for the SR1a. With the JotR I have long since bypassed the inbuilt baffle step correction with the same benefits people have found here. Greater clarity, deeper bass and generally better bottom to top tonal balance. It's worth noting that experimentation has shown me that the JotR will clip in the bass long before the ribbons complain when bass heavy music is played.
The bass of the SR1a is very good when correctly compensated, it just lacks the overhang characteristics of traditional cupped headphones. I bought 1266 TCs recently, used them for a couple of months (using my Benchmark AHB2) and I just sold them - they are great fun but I cannot say they gave a compelling performance compared to the Raals. The Raals were easier to wear, the Abyss 1266's required such a specific set up to get a good clean(ish) bass response. I did enjoy the Abyss headphone in isolation and if I didn't have the Raals I'd probably have been very happy with the them, but I stopped choosing them to listen to.
The CA1a is probably going to end up in my hands but I shall replace the resistor box with the transformer one for use with the SR1a first.
May 12, 2023 at 9:34 PM Post #6,649 of 7,885
guys, try this album with the sr1b/ca1a. simply amazing. lovely vocals and very textured, detailed percussions. nicely recorded album! am enjoying every track!
May 12, 2023 at 9:40 PM Post #6,650 of 7,885
Thanks for the heads up! Listening to it now. For those who also have the Susvara, it sounds excellent on it as well. :)
May 13, 2023 at 10:01 AM Post #6,651 of 7,885
What have your observations been?
Much more open sound, more forward -- you do need a powerful amp and the filters.
It's a real middle ground of CA-1a + SR1a.
May 13, 2023 at 10:07 AM Post #6,652 of 7,885
Really cool... @Aleksandar R. suggested I try holding the CA-1a next to my ears without the pads... I suspect that is more of the sound you are hearing.
May 13, 2023 at 10:14 AM Post #6,653 of 7,885
I want to say without the pads there was quite a bit of diffuse behavior, so I might just suggest holding the regular pads off your ear a bit that may help gleam the sound.
May 13, 2023 at 7:55 PM Post #6,654 of 7,885
Well, this combo sounds just about perfect. very well controlled highs and superb bass. love the staging on the ca1a; this always seems to surprise me the most. half expecting a narrow stage but the way the Ca1a throws stuff far front and out the side is amazing.
May 13, 2023 at 9:03 PM Post #6,655 of 7,885
Agree about the CA-1a. It tends to be underrated. I think they did a fantastic job with it. And it is so reasonably priced as well.
Can‘t wait to receive the 10 foot Star8 cable and the HSA-1c in due course. Will also consider the 6 foot Star8 cable thereafter for the TI-1b. :)
May 13, 2023 at 9:40 PM Post #6,656 of 7,885
wow, that is a great cage for the tubes, mine is naked lol.....where did u get it?
May 13, 2023 at 9:45 PM Post #6,657 of 7,885
It's a rare piece.. I asked about the tube cage holes on the vm1a and Aleksandr hooked me up with one of their prototypes. not sure if they are intending to make any more cages. it was shipped directly from Dragan @ Solaja Audio.
May 13, 2023 at 11:05 PM Post #6,658 of 7,885
thanks for the info,I imagine it is pricey
May 14, 2023 at 7:48 PM Post #6,659 of 7,885
May 15, 2023 at 7:19 AM Post #6,660 of 7,885
Imagine my delight today when Wilson from Jaben Singapore pinged me to tell me that the SR-1b and CA-1a has arrived at the store.
I popped by to help Wilson set up the Schitt Jot R set up as well as the TI-1b set up. So that it is all ready for anyone who wishes to try out the SR-1b and CA-1a. On a direct drive amp like the Jot R as well as off the TI-1b. :) Exciting times!
Wilson was quite blown away by the RAAL Requisite ribbon HPs, as I had promised he would be. :)
