Kiats
Hi Kiats,
No, it will kill highs too much. While it's large onductance was very nice for the JotR, it is way too high for the transformer interface.
Will it work with the HSA-1b @Aleksandar R. ?
Hi Kiats,
Thanks man! Heheh! One step at a time. Let me soak in the SR-1a and the JR first. Before I ponder the HSA-1b or the TI-1b and Star 8. I am wondering if it makes more sense to get the TI-1b or the HSA-1b. I am very tempted to have the JR/deluxe cable and the TI-1b and Star 8 10 foot cable as 2 separate set ups. Any thoughts?Welcome to the club! If you want to further elevate the sound, you can get the convolution filter from Mitch (Accurate Sound).
And yes, you should try the CA1a as well (w/ Star 8 cable) paired with Mitch’s filter. It sounds phenomenal
Yes take it slow and enjoy the SR1a.Thanks man! Heheh! One step at a time. Let me soak in the SR-1a and the JR first. Before I ponder the HSA-1b or the TI-1b and Star 8. I am wondering if it makes more sense to get the TI-1b or the HSA-1b. I am very tempted to have the JR/deluxe cable and the TI-1b and Star 8 10 foot cable as 2 separate set ups. Any thoughts?
Will take it nice and slow. If I rush, then I won’t fully appreciate any upgrades.
How is the CA-1a by the way? I am a bit concerned about the foam ear pads. Will they deteriorate like Grado earpads?
Thanks man! yeah… I fully intend to. Besides, there’s also my Stax rig and of course the CRBN. So many gorgeous audio stuff and only one pair of ears…Yes take it slow and enjoy the SR1a.
The foam is quite sturdy and firm, I don’t know how long it will deteriorate, but it’s very easy to replace and Raal sells the pads.
Never mind about my question. I just solved this by using a Benchmark adapter cable I had in storage. I used the RCA outputs of the Benchmark DAC3B into the XLR inputs of the VM-1a. The cable is RCA on 1 end and XLR male on the other. The RCA outputs is also 12dB lower than the XLR. This works really well now. I can adjust the volume from the VM-1a anywhere on the dial. Note that the DAC3B does not have a volume control.
Danny, I do not think my VM-1a is in need of any repairs. Thanks for the idea. Though I think I am going to need a better quality cable. Normally, these Benchmark cables are good enough, but in this case, it seems a little less revealing than the Audience AU24SE interconnects I normally use.
I was reading page 18 of the manual last night. which has the following. A little confusing now, but I will change the jumpers today to test. Positive vs negative attentuation.u can adjust the gain on xlr outputs in the dac3b using jumpers.
I have an X1, and while I don't have the VM-1a, I do have the HSA-1b. I use the Leedh volume processing through the Lumin, with the HSA-1b volume set to unity gain, which since it uses an attenuator (same as your VM-1a), is positioned all the way wide open. I then adjust my volume through the Lumin...or in my case, through my tablet since I use Roon. It sounds absolutely marvelous in this way. If you're using the Leedh processing, which is the default, then your pre-amp volume....in this case the Raal amp, needs to be in a fixed position all the way up for it to sound its absolute best.I am having with my VM-1a and my Benchmark DAC3B. The DAC3B's gain is rather high, thus I have very low granularity on the VM-1a's volume. It did not bug me before, but it would be better to be able to change to more higher volume settings.
I have a Lumin X1 that has a NORMAL and LOW analog output setting at FIXED volume (so no preamp circuit involved). I tried the X1 at LOW and the VM-1a's volume can now be adjusted to many higher settings without screaming at my ears.
The Lumin X1 DAC is preferred for my 2-channel since I listen during the daytime (more hours) with 2-channel. The nighttime is RAAL time. My question to you VM-1a owners is what DAC are you using with the VM-1a that is allowing for normal volume adjustment? What are some other neutral sounding DACs that have a low volume setting on FIXED volume configuration? The VM-1a is also a preamp so I do not want to use a DAC with VARIABLE volume output configuration.
BTW - the X1 and VM-1a are a killer combo.
The X1 also worked great for me too. I set it too wide and set the GAIN to LOW on the Lumin app. The LOW GAIN setting only affects the X1's DAC output and not the SPDIF or USB output. This works amazing. However, I do not want to use the X1 with the VM-1a. I listen more with my 2-channel 9-5 while I work and want the Lumin for that. The Benchmark DA3B is now just for the VM-1a. Surprisingly, I like the DAC3B with the VM-1a the most.I have an X1, and while I don't have the VM-1a, I do have the HSA-1b. I use the Leedh volume processing through the Lumin, with the HSA-1b volume set to unity gain, which since it uses an attenuating volume pot (same as your VM-1a), is positioned all the way wide open. I then adjust my volume through the Lumin...or in my case, through my tablet since I use Roon. It sounds absolutely marvelous in this way. If you're using the Leedh processing, which is the default, then your pre-amp volume....in this case the Raal amp, needs to be in a fixed position all the way up for it to sound its absolute best.
no worries, I have had no issue with them and even if they did degrade they are a snap to replace and cost a few dollarsThanks man! Heheh! One step at a time. Let me soak in the SR-1a and the JR first. Before I ponder the HSA-1b or the TI-1b and Star 8. I am wondering if it makes more sense to get the TI-1b or the HSA-1b. I am very tempted to have the JR/deluxe cable and the TI-1b and Star 8 10 foot cable as 2 separate set ups. Any thoughts?
Thanks for the heads up on that. Yeah… I am just wondering if i want to get the TI-1b and Star 8 or the CA-1a first. Decisions decisions. I suspect I will continue using the Jot R and Deluxe cable first. Reason is simple: I understand (now that I have found @Aleksandar R. ’s previous post in September after manually reading thru all the posts in respect of the Star 8 cables (HF search is not so easy to use) that you really need the 6 foot cable to be used with the TI-1b. Not quite my cuppa since I usually need at least 8 footer cable cos of where my sofa and my desktop rig is situated.no worries, I have had no issue with them and even if they did degrade they are a snap to replace and cost a few dollars
It’s all relative. If you read my statement that HSA-1b is thinner, that’s compared to the VM1a. I am perfectly happy with the HSA-1b as well. Mitch’s convolution filters help boost the bass if you want.Unless i go the whole hog and get the HSA-1b and use it with the 10 foot Star 8. But I read one of the impressions in the thread that the sound out of the HSA is thinner, but I read published reviews that claim that the HSA-1b is more musical and richer in tonality. A bit confusing...
The issue with 10ft STAR-8 on the TI is that it will be ~4dB quieter than a 6ft, and you have to use more power to compensate. Otherwise, it works just fine on a TI.@Aleksandar R. Quick Q: I noticed that the Star 8 cable comes in 6 ft or 10 ft. Am I able to use the 10 footer with the TI-1b and SR-1a? No issues?
The other question is this: is the 10ft Star 8 cable something that can be used with the Jot R. I recall you saying that the 6ft one is not suitable.
Thanks!
Stay updated on RAAL 1995 at their sponsor profile on Head-Fi.
With using the TI, with either SC-2 cable (that comes with it) or the 6ft STAR-8, you can extend the length of the input cable. 10-15ft, no problem.Thanks for the heads up on that. Yeah… I am just wondering if i want to get the TI-1b and Star 8 or the CA-1a first. Decisions decisions. I suspect I will continue using the Jot R and Deluxe cable first. Reason is simple: I understand (now that I have found @Aleksandar R. ’s previous post in September after manually reading thru all the posts in respect of the Star 8 cables (HF search is not so easy to use) that you really need the 6 foot cable to be used with the TI-1b. Not quite my cuppa since I usually need at least 8 footer cable cos of where my sofa and my desktop rig is situated.
So perhaps makes more sense to stick to the Jot R and Deluxe cable and pick up the CA-1A next.
I do like the sound signature of the Jot R thus far (out of the IFI NEO Stream or Bricasti M1): transparent and open yet pithy and nuanced. This is nicely aligned with my preferences.
