Hello: I have posted on other Head-Fi threads, mostly on Kennerton headphones and Benchmark HPA4 headphone amps. Recently I bought an SR-1b and Ti-1b transformer interface and also purchased a Star 8 headphone cable. I stream Qobuz via Roon using a Bricasti M1SE DAC with network card, then into my HPA4 connected to the Ti-1b using its 16 ohm input. Since the HPA4 outputs 6 watts into 16 ohms and 3.5 watts into 32 ohms, that is probably why I found the 16 ohm connection to sound a little better and it has a higher output. I use a small amount of parametric equalizer compensation on Roon. For inquiring minds I use a +2 dB low bass shelf beginning at 170 Hz with Q 1.0 and a dip centered at 2 kHz of 4 dB and Q 0.5. Since I don't listen that loud I have not heard any type of clipping.
I have really been enjoying these phones listening to classic and progressive rock and jazz mostly. I have a pair of neutral-sounding Kennerton Rognir planar magnetic cans and also a pair of modified Kennerton Gjallarhorn GH50 JM Edition phones, which are warm, dark, and bass-prominent, read: bass cannons or Eargeschplitten Loudenboomers. I am not really as much of a fan of bass-prominent phones, far preferring the more neutral sound of the Rognirs and certainly the SR-1b. All I can say is that once you hear the speed, detail, spaciousness, and transparency of the SR-1b, the exciting, alive sound of bands when using these phones, who cares about bass quantity. And the bass quality is the best I have heard, bass guitars having that thrum and bass drums having that thwack of real life. Phones that seal the ear canal, i.e. almost all other phones produce bass through compression and rarefaction instead of in free space, which is why the use of a midrange driver can produce prodigious bass in a small enclosed cavity.
I only listened for a few hours using the stock SC2 headphone cable before buying the Star 8 but in my estimation the S8 cable makes for a more balanced sound while still sounding as detailed. I would guess the lower midrange and bass to be increased slightly and they sound more spacious and detailed at the same time.
The Benchmark HPA4 is as you can imagine extremely neutral and detailed, being a SS amp with unmeasurable TIM, THD, and crossing distortion with the highest signal-to-noise ratio ever measured, at least on Audio Science Review. I have always liked a fast, detailed, maybe even treble-prominent sound. To my ears, most phones have way too much bass that overwhelms the rest of the music, maybe because we have been conditioned to this type of sound. Nothing is worse in my book than slow, dark, plodding, bass-heavy sound. The SR-1b is the antithesis of this sound and I fell hopelessly in love with it. When I had a 2-channel system I had a pair of speakers using Audio Nirvana single-drivers and sat nearfield, so this probably contributes to why I like the SR-1b so much. The coherence of single drivers without the phase problems and sounds emanating from different diaphragms and different points in space.
Thank you for all your posts and I look forward to your continued information on these great phones.
