SageM
Member of the Trade: RAAL-requisite
Thanks for asking about the Headphone Power Base (HPB-1a). I should mention, we really have our hands full with current products, so it's going to be awhile before we can bring the HPB-1a to market. Alex built a large scale version (full 2-channel system) of this technology several years ago and has been enjoying and refining it, all this time. I happen to have a small scale headphone version, which I am also enjoying.@SageM or @Aleksandar R. would it be possible to talk more about your upcoming power base HPB-1a?
Does it have a similar footprint to your amps?
Is there a switch to go between 115V and 230V?
Is it only intended to support one amplifier or upstream gear like a DAC and streamer too?
For now, there isn't a lot that I can confirm, only because the scaled down headphone version is still under development, which will inevitably mean unforeseen tweaks to size and layout.
In general, it will be roughly the size of our VM-1a and weigh a little less. It is suitable for all voltages, 115V, 230V, 100V (Japan) and anything reasonable you throw at it. Power input is via IEC so you can use a proper, locally sourced, power cable with IEC at one end. Because the system is 1:1, output voltage is same as input (source) voltage. There is no need to select a voltage, it's whatever you happen to have coming out of the wall. It does not step up or down. Power output jacks (3 or 4) are multi-national type, which will cover North America and most international plugs.
The first model will be scaled to cover the current demands of most headphone systems (audio player, DAC and headphone amp, etc...). A second model will follow for the slightly higher current needs of bigger amps, like our VM-1a or equivalent.
It will have a voltage, current and hertz meter which indicates you are drawing current, to the degree in which it allows the permeability of the core to perform as intended. This is why a slightly larger model is required for higher current applications. In other words, there is a sweet spot or range that is most effective for various loads.
Alex has a large batch of meters (50+) that have been under test for about a year, now. So far, no failures and all continue to read correctly.
The HPB-1a is a headphone product we expect to be well received.
Thanks again for asking! Danny McKinney
